VIs callers
I opened a VI in LabVIEW and I want to find out which VI's call this VI. When I go to VIEW - Browse Relationships I find this VIs callers sub-menu is dimmed. Why? What's the solution?
Thanks for helping!
Message 1 of 8
(4,653 Views)
May be there is a possibility that no vi is calling your vi.
Or attach your that particular vi. we will find the problem.
Mathan
Message 2 of 8
(4,652 Views)
Hi rashid,
you can only see the callers, if they are in memory.
Mike
Message 3 of 8
(4,648 Views)
Thanks MikeS81! I think you are right. Since that was the only vi loaded in memory so that's why LabVIEW could not find its callers.
Thanks for helping!
Message 4 of 8
(4,636 Views)
Hi Rashid,
one solution would be to open all VIs at once that are suspected to be the caller, then you can search your VI with the search window. Or you drag them all into a blank VI's block diagram.
Another solution is to use VI Server, as sketched in the attached VI.
Hope this helps,
greets, Dave
Greets, Dave
Message 5 of 8
(4,624 Views)
Thanks daveTW! Both solutions are great. The VI you shared is for LabVIEW version 8.5. I am using version 8.2 at the office. However I've got 8.5 installed at home. I'll check out your vi later at night. Thanks for sharing!
Message 6 of 8
(4,617 Views)
Hi rashid,
here it is for 80
Mike
Message 7 of 8
(4,613 Views)
How kind of you, MikeS81! You are an angel!
Have a very nice day!
Message 8 of 8
(4,608 Views)
