VIs immediately tagged dirty on open
If all I do is open a VI- I don't even click the mouse, change views or ANYTHING, it gets the asterisk in the title showing it has been changed.  But nothing has changed.
How do I stop this behavior which includes asking me if I want to save on close?
Message 1 of 16
(3,988 Views)
Do you have the "Seperate From Compiled" turned on for the VI?
Message 2 of 16
(3,985 Views)
I've never set that property, so it is set to whatever is the default value.
Message 3 of 16
(3,982 Views)
Then that is likely your problem.  If something in a subVI changed, that would cause this VI to have to recompile, therefore causing a change in the file.  If you have the seperate from compiled turned on, then the compiled code is not saved with the source code and you will not need to resave just due to a subVI changing.
There is an option to have it on be default.  I highly recommend using that.
Message 4 of 16
(3,976 Views)
I haven't changed anything in a sub-vi.  I start LabVIEW open a sub-vi and it is tagged dirty.
Message 5 of 16
(3,974 Views)
What does "List Unsaved Changes" say?
Message 6 of 16
(3,930 Views)
How to Check "List Unsaved changes"?
Message 7 of 16
(3,882 Views)
Hi PAnand,
close the subVI without saving it before. Then LabVIEW will ask you for saving with presenting a dialog where you can "check for unsaved changes"…
Message 8 of 16
(3,875 Views)
@GerdW wrote:
Hi PAnand,
Thanks Gerd I never noticed before.
Message 9 of 16
(3,869 Views)
Also in the VI Properties window is a "View Unsaved Changes" button.
Message 10 of 16
(3,847 Views)
