VRML
Hi metadeth
i will send for u a JPG that u will can save your file with VRML 97
regards
Message 11 of 56
(4,222 Views)
Hi metadeth
I send for u.if u have any question please tell me
regrads
Message 12 of 56
(4,222 Views)
thank you, I finally could open the vrml  😃
Message 13 of 56
(4,190 Views)
Hi Naser I have another question, could you tell me how to import 2 or more objects in vrml format and give them parent and child attributes, I downloaded a file you posted but I couldn't open it, I hope you could help me again, thanks 😃
Message 14 of 56
(4,185 Views)
I the picture attached, you will find how to assign children to a parent object.
 You can find all you want in the VI "solar system.vi".
Hope will help....
Marc
Message 15 of 56
(4,175 Views)
Hi metadeth
 I don't understand your question correctly.
Do u have a VRML file or more of ones?
But I know that first your children of VRMLs must have a name.
I don't access to Labview now.
We can communication with our mail if u want.
Best regards
Message 16 of 56
(4,163 Views)
Hi metadeth Do you solve your problem? if not: first u must to install labview 3D picture from http://zone.ni.com/devzone/cda/tut/p/id/4411 Then you have to open your VRML file with a software that it can open VRML file for example V-Realm builder. Then you have to define and specify for children. i will send a example of my project for you. Best regards
Message 17 of 56
(4,117 Views)
Hi metadeth Do you solve your problem? if not: first u must to install labview 3D picture from http://zone.ni.com/devzone/cda/tut/p/id/4411 Then you have to open your VRML file with a software that it can open VRML file for example V-Realm builder. If have Maltlab you can use V-Realm builder in Matlab. It is a software in Matlab. Then you have to define and specify for children. i will send a example of my project for you. Best regards
Message 18 of 56
(4,114 Views)
Hi Naser, I solved the problem thank you =), do you know if it's possible to change center of rotation of an object??, I want to rotate a squared shape but it rotates from a corner not from the center of it, I had to put a cylinder and make it a parent for the square and then rotate it, it worked but I want to know if it's possible =), Where can I get V-realm builder??
Message 19 of 56
(4,094 Views)
Hi metadeth
Do you have Maltab?
Yes it is possible to rotate a cylindrical by center not corner.
Please send your VRML file and your labview file if it possible.
I will send a file of it has a cylindrical shape.
I will rotate this shape by corner and center separately.
best regards
Message 20 of 56
(4,083 Views)
