Validate xml
i want to validate the attached xml file with the attached schema file.
how can i do it with labview? can someone do a small example?
Thanks!
(3,129 Views)
No one can help me?!
(3,112 Views)
Step 1: Learn patience. This is a public forum, and questions are not answered immediately. Sometimes they are, depending on who's logged in. If you need immediate assistance you should contact NI tech support directly.
Step 2: Have you tried a search? http://forums.ni.com/ni/board/message?board.id=170&message.id=184947
The XML functions in LabVIEW do not do validation. This means you need to use third-party software. There is also EasyXML, but I'm not sure if that does validation.
Message Edited by smercurio_fc on 07-16-2008 09:46 AM
(3,108 Views)
Thanks for your answer.....usually i get an answer very fast....you guys spoiled me :).
(3,097 Views)
