Value change event for external activex control
Hi All,
I am trying to know how to fire the value change event for the (externally available) button inserting into activex control. From the available properties of that button I could not find anything relevant to a value property of lv boolean buttons. But I have used this ocx button in VB application earlier.
Thanks.
(2,683 Views)
Hi there
Do you want to FIRE the event from LV or do you want to CATCH the event inside LV?
To CATCH an event from an ActiveX control use the "Register event callback" function from the Connectivity\ActiveX palette.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,682 Views)
Yes I  want to fire the event from LV.
Thanks.
(2,661 Views)
