Value of a ring
I would like to create a ring with non-sequential values in it.  I want to get the value from the ring without converting the ring into a number and without getting a coercision dot.  Is that possible?
Yik
Kudos and Accepted as Solution are welcome!
(2,684 Views)
Yup, check the Properties of a ring control and you can edit the representation and value of it.
Qestit Systems
Certified-LabVIEW-Developer
(2,682 Views)
Oh, I think I got confused for some reason.  Thanks!
Yik
(2,678 Views)
