‎08-22-2011 03:28 AM
Hi Mitsurugi,
Wow that seems rather peculiar!
What I would recommend is to repair the installation of your LabVIEW program. Go to "add/remove programs" (or equivalent), select the National Instruments folder, then LabVIEW & click repair. Let me know if this has any effect on the blank buttons.
Regarding your questions, with the images I just opened them in paint then saved as .png type. Import from file or import from clipboard shouldn't make much difference, but I personally just used the clipboard. I think the advantage is just personal preference with which method you'd prefer to use.
Which control palette did you select your Boolean control from? I used the "modern" palette if you want to try that?
Would definitely recommend the LabVIEW repair firstly though.
Fingers crossed!!
‎08-22-2011 07:28 AM
@Mitsurugi wrote:
Hullo Tori.
The answer to your question is Yes AND No.
All you state was the "No" part. What do you mean by "Yes?" Did it work or didn't? Somewhat? Just curious. Have you tried a different image?
‎08-22-2011 08:26 AM
Hiya MoReese, when I said "Yes and No", I meant that whilst what Tori sent over worked great (didn't disappear), the problem still persisted when I tried to use those buttons in MY own project.
Tori - just upgraded my installation of Labview, in the hopes that it WAS a dodgy installation, though, my colleague is taking a look at the problem now and he's experiencing the same issues.
I'll try re-saving the images, and if that doesn't work then there's always the unistall/re-install option...
Mitsurugi
‎08-22-2011 09:07 AM
I don't think "repairing" LV will fix it. Remember, initially, I experienced the same problem as you (I'm using LV2010). Perhaps it's your VI that is corrupted. Repairing LV won't cure that problem. Try recreating the VI if you haven't done so already.
‎08-23-2011 05:07 AM
‎08-26-2011 08:16 AM
‎08-26-2011 04:19 PM
I'm glad to hear it's working. Those are the most frustrating problems, the one's that just go away. Oh well, if your unlucky, you may get a second chance at it in the future.![]()
