Variable Engine crash
Hi Logan,
I am currently working with Vincenzo through support. We are trying to understand why this doesn't work on multi-core, rather than how to get LabVIEW not to run. However, this is a great suggestion and maybe the perform of LabVIEW/DSC won't be affect to much running on single core. Thanks for the suggestion!
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
Message 11 of 13
(1,633 Views)
Hi All,
I actually have Windows API example code to switch LabVIEW to single core... so we can look into this option.
Kind Regards
James Hillman
Message 12 of 13
(1,628 Views)
Hi All,
The current status of this issue is as follows:
This issue was reported to R&D in Corrective Action Request (CAR): 173604.
After investigation the root cause was found to be a bug in the OPC IO Server diagnostic information logger: it is not thread safe.
There are currently two simple workarounds:
  1. Disable the Diagnostic Logger:
    a. Right-click on the I/O Server Variable in the LabVIEW Project
    b. Select Properties
    c. Select the Diagnostic tab
    d. Uncheck Enable Diagnostic
  3. Disable Multicore operation within the PC BIOS (if supported).
R&D is currently working on a fix which may be released in the
future. Please refer to CAR 173604 for the latest information. Please contact your local NI Office if you require further support regarding this issue.
Kind Regards
James Hillman
Message 13 of 13
(1,591 Views)
