Variable Graph Plots
Is there a way we can do a similar plot using LabVIEW graphs?
- Sable
(3,934 Views)
Yes, but it would be a lot of work.  LabVIEW is designed for Engineering (the "E" in LabVIEW) -- other programming languages (MatLab, Excel) would seem better suited for creating the plots you describe.  "When your only tool is a Hammer, every problem looks like a Nail".
Bob Schor
(3,911 Views)
Bob's right, lots of work to re-create that plot type.  Probably only common is statistical packages.
There's code available to create box plots - https://forums.ni.com/t5/Example-Program-Drafts/LabVIEW-Box-Plots/ta-p/3506533
The formatted axis will be harder.  If its always the same labels then you could just use an image of the right size.  If the label change then you could take an approach like the one outlined here - https://forums.ni.com/t5/LabVIEW/Edit-X-scale-label-from-numeric-to-text-in-Waveform-Graph/td-p/3553...
Craig
(3,902 Views)
Is it possible to import the matlibplot library into LabVIEW to use the graph formats?
- Sable
(3,898 Views)
- Sable
I know you can import a C# library You're going to have to use activeX
Here's a link that may help:
http://www.ni.com/pdf/seminars/pt/seminario_labview_matlab.pdf
(3,891 Views)
