Variable Reluctance Sensor simulation
I am a student who has just started using labview and am trying to simulate a variable reluctance crank sensor signal from a motorbike engine. A toothed wheel (12 teeth minus 3) is mounted on the crankshaft and has 3 teeth missing to allow the crankshaft angle to be determined. The resulting waveform is sinusoidal like where one cycle represents one tooth. The gap where the teeth are missing produces a flat line.
What i would like to do is simulate this signal approximately by producing a sin wave that cycles 9 times and then produces a flat line to represent the gap. This whole process would be repeated indefinately. Could anyone nudge me in a right direction.
(4,659 Views)
Hi Erny.
Here is a very simple example. Do not brake throttle Smiley Wink
Message Edited by EVS on 08-25-2005 06:01 PM
Jack
Win XP
LabVIEW 6.1, 7.0, 7.1, LabWindows/ CVI 7.1
Let us speek Russian 🙂
(4,655 Views)
Thanks thats perfect, much appreciated.
(4,637 Views)
