Variable filename
I'm doing a project where I have to take snap shots from a video camera. I've manage to do this part but I can't create a variable file name to save the images. If I can take the variable out of a while loop, in every loop, I can use this value to name the file.
Thank You Guys...
(2,828 Views)
duplicate post
Do not mark your original question as solved and then ask the same thing. Unmark the solution (click the Options button) and respond back in the original thread. DO NOT resond here.
(2,824 Views)
