Variable in case selector label
Hello everyone.
Probably it's a trivial problem but I can't work it out.
I need to create a case structure with 3 cases:
First case if x < c
Second case if x = c
Third case if x > c
where both x and c are variables. I can't believe the only way is nested case structure. I know selector labels can contain a range like 0...4, but what if instead of 4 I have a variable (c)??
Any help is really appreciated.
Matteo
(4,725 Views)
Accepted by topic author matteo.bart
Subtract your numbers.  Then in the numeric palette is a function called "Sign".  It will return -1, 0, or 1 based on the sign of the value passed into it.
(4,710 Views)
Yes,that was really easy. I had not seen Sign function. Thank you very much.
(4,689 Views)
Be careful. That may not work for all cases. There is always a problem in comparing DBLs to zero or to each other (i.e., x=0  or  x=y). I attached a snippet as an example.
If you type in the values of 0.1 directly into the controls, the result of the "Sign" is as expected.
If the Values are computed from other control  values you get an unexpected results
I SUBTRACTED two DBLs and the results is ~0.1
I DIVIDED two DBLs and the results is also ~0.1
However 0.1 - 0.1 <> 0 in this case. The results of the "Sign" function is 1!!
(4,673 Views)
You're right. In my case I subtract integers so it's ok. Thank you for the clarifications anyway.
(4,663 Views)
