Variable nomenclature in .NET
I am new to using .NET.  Often in a listing of a node (property or invoke) the selections begin with [S]. Can anyone clarify what that indicates?
Thank you
SWJ
(3,398 Views)
The S is for static.
Static mean that the reference is not needed, the function returns the same value. You shouldn't need to wire a valid, initialized .NET object.
(3,358 Views)
Thank you.
(2,261 Views)
