05-26-2013 09:35 AM
05-26-2013 10:35 AM
I have not used ELVIS, but from looking at the specifications, it appears that the positive and negative variable supplies are separate. It also appears that they may share a common ground.
So, you will need to use some kind of switching device to reverse the polarity of the motor. 4 transistors with suitable power ratings connected in an H-bridge configuration will work. You may need level shifting and other circuitry to drive the high-side transistors.
Another option is a relay.
Lynn
05-26-2013 01:30 PM
This propose with 4 transistors (H-Bridge) is good but then I can't use Variable supply to drive transistors, as I need two outputs which should be switchable. In other words they should be able to change polarity so oposite transistors can conduct. I could use digital outputs, drive them with PWM, but it's too complicated for me.
The best way maby would be to generate two PWM's (in quadrature) using Analog outputs (arbitary waveform generator) and H-bridge, but I don't know how to accomplish this
05-26-2013 01:40 PM
You can still use the variable supply to change the motor speed. You need only the positive supply. Only switch the H-Bridge when you want to change the direction. Control the transistors with digital outputs. Since you are not too worried about efficiency, I suggest a modified H-Bridge where the high side transistors are p-channel MOSFETs or PNP BJTs. Then they can be driven with ground referenced logic plus some simple level shifting. No PWM required.
Lynn
05-26-2013 02:16 PM
This is good. I dodn't figured out that i can use variable output as power suply for H-bridge Now i know how to implement hardware design.
Thank you very much for response.
05-26-2013 02:31 PM - edited 05-26-2013 02:33 PM
Please post back after you get it built and let us know how it worked.
Another note: If you will ever try to reverse the motor while it is running, you will get large transient currents in the H-bridge transistors. Consider adding appropriate protection diodes or other devices.
Lynn
