Variant Array Problem
I am having a problem with variant array conversion.
A VI gets a 1D array of generic data type as variant. This VI generates a 2D array of this and passes this to a third VI which has to write that data into a 2D array by the "Value" Property as variant of a control element.
I somehow cannot convert the 1D array of variant into a 2D array of data.
I can demonstrate it with a simplified VI that is demonstarting the problem.
I hope someone can help me out.
Message 1 of 12
(5,173 Views)
Message 2 of 12
(5,169 Views)
You cannot directly convert an array of variants (of 1D arrays) to a 2D array. "Variant to data" accepts a variant, not an array of variants.
What are you actually trying to do with all this?
Message 3 of 12
(5,152 Views)
You have a 1D array of variants.  This'll get your 2D array back.
Or, move the To Variant node to the inside loop.
Jim
Message 4 of 12
(5,147 Views)
...or, to the outside of both loops.
Jim
Message 5 of 12
(5,130 Views)
Sorry, my example doesn't reall describe what I need to do.
I created a new example. The VI architecture is fixed and the data generated by Sub 1 is generic. It can be numeric, string, bool..
I nned to be abl eto write the 2d array by reference to the control and hope somehow to do it without another conversion step.
Message 6 of 12
(5,120 Views)
Somehow cant attach zip files
Message 7 of 12
(5,119 Views)
Your first problem is that you want to put a string into a numeric indicator.  That's not gonna work.
A smaller problem is the way you're putting the array of variants into another variant in sub 2.  This works if you change the False constant to True in sub 1:
Jim
Message 8 of 12
(5,086 Views)
Jim
sorry for the confusion with the boolean constant. It was meant to write the numeric values.
I found a workable solution for me. It works, when scalar valuse are converted to variant and then arrays of variant are built.
Message 9 of 12
(5,075 Views)
How are you going to handle this?
@DAckermann wrote:
[...] the data generated by Sub 1 is generic. It can be numeric, string, bool [...]
Jim
Message 10 of 12
(5,056 Views)
