Variant as Input VI terminal
Hi fellow developers,
I want to ask if anyone knows how to connect a variant as a connector terminal for my SubVI? I can't find a variant control at the moment.
I have used variant to data and unflatten to string and no Refnum for my SubVI.
Can anyone enlighten me?
Alan.
(4,216 Views)
Under the Variant and Class Palette on the modern control palette.
(4,209 Views)
Accepted by topic author saintalan94
Location of Variant Control
At times when I'm not able to locate any specific control/indicator, I prefer to right click the function block (node) on the block diagram and select 'Create' >> 'Control' (or 'Indicator')...
'Right Click' and create
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(4,190 Views)
There's also the option of QuickDrop - CTRL-space on the front panel and type what you're after. The downside is that it doesn't teach you where it is on the palettes.
CLA
(4,177 Views)
That's what the Search button in the pallets is for.
(4,158 Views)
