Variant to Flattened String prim crashes LVRT 2013 on a cRIO-9074
LV 13.0f2 (32-bit)
Executing this code on a cRIO-9074 crashes the target. Executing it on my Windows 7 x64 PC runs fine. I don't see any indication in the documentation that it shouldn't work in RT...
(2,558 Views)
Hi Staab,
I tested your code in a cRIO-9074 and effectively was able to reproduce this behavior. After deploying and running the code, I would then get the ''Waiting for the target to respond message'' in 2013. I wanted to let you know that CAR# 193471 was filed for this behavior and R&D is currently aware of it. Thanks for posting it!
(2,510 Views)
Thanks. Is there any workaround for getting the type desriptor of a cluster? A different vi.lib function or another way of writing the code? I really need the type descriptor for part of an app I'm working on right now.
(2,504 Views)
