Variants in LV 6.02 ?
Hi ,
so now we the Christmas, but I dont now waht is happen with varients in
Labview.
I would like to transfer from any c++ per com an event with 2 parameters
(long int, long int) in labview. When the event is com in i would like have
the tow parameters. The event is in funktion but the parameters coms as
variant former the variant funktion from labview crash (type long int with
array i atempt) can any body help me ?
So best regards from Reiner - Leica
(2,397 Views)
I'm not quite sure what you are working on, but I can try to help you out. Let me see if I've got the idea. You have a C++ DLL that you want to call from LabVIEW and the function you are calling requires a variant as input? Is this correct? Does this cause LabVIEW to crash? Let me know and we can try to work at this.
Also, if it would be easier for you, you can contact your local NI Branch office if there is one. They can provide support in the native language, so that may be easier for you. For instance, if I were in Germany, I would contact germany@ni.com. Let me know if I can help you out.
J.R. Allen
(2,397 Views)
