Vector CANcardX and LabView
Anyone had luck with using the Vector CANTech example using their CANCardX?
This is high speed CAN (Controller Area Network) used primarily in
automotive...
Chris
(3,201 Views)
Chris,
I've recently used the Vector CAN-AC2-PCI cards for an automotive application and have modified the Vector supplied LabView drivers, VLabLib.llb to simplify the usage from within LabView 7. Vector's technical support was very responsive in helping to overcome some of my problems dealing with the vcanap.sys driver and may be helpful for your problem. Please provide more specifics to the problem you're having.
Todd.
(3,201 Views)
