Vector XL Driver Library 9.0.34
Error 1097...
LabVIEW:  An exception occurred within the external code called by a Call Library Function Node. The exception might have corrupted the LabVIEW memory. Save any work to a new location and restart LabVIEW.
Have you got the hardware working with any other software? Is it listed properly in the Vector hardware configuration dialog?
It sounds to me like the driver installation is incomplete or corrupt.
Are you using the 32bit version of LabVIEW or 64bit?
You're using version 9.7.26 of the "xl driver library", what version of the "Vector Driver Setup" do you have installed?
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 11 of 14
(1,734 Views)
Hello Troyk
The hardware is working with the ECU Diagnostics Tool alsothe Vector hardware configuration dialog i dont know if the configuration is correct,im pretty new on Vector and i using Labview 64 bits
For Vector Setup im using 8.2.98
Message 12 of 14
(1,723 Views)
Hello Troyk
Message 13 of 14
(1,723 Views)
@jorgeglz wrote: i using Labview 64 bit
Using 64bit LabVIEW to call a 32 bit dll is the cause of the problem.
You will need to either use modified versions of the wrappers that call the 64bit dll or use 32bit LabVIEW.
In the comments of the community document someone says they have already made the changes to the wrappers to call the 64 bit version of the dll but they never posted these 64 bit version of the wrappers. Maybe you can contact them to see if they will share it or make the changes yourself.
Message 14 of 14
(1,713 Views)
