Velleman PC Function Generator K8016
Hi
Does anyone know if there are example programs for the Velleman PC function
Generator?
Cheers
Wayne
(2,844 Views)
Thank you for contacting National Instruments.
I am not seeing any drivers for that particular instrument in our Instrument Driver Network. You can access and search this network yourself at www.ni.com/idnet.
You may want to contact your instrument manufacturer directly to determine if they have developed a LabVIEW driver specifically for that instrument. You can also request that a driver be developed for that instrument at www.ni.com/idnet. Submitting a request does not guarantee that a driver will be made, but if there is enough interest, it will prompt development.
As far as example programs are concerned, you can always experiment with the VISA functions and use the VISA examples to communicate with your instrument. I have attached
an example VI that provides a basic illustration of how to use the VISA functions. You can find additional examples by going to Help >> Find Examples >> Hardware Input and Output >> VISA.
I hope this helps!
Matthew C
(2,844 Views)
