VeriStand model from LabView project - problem with inports
Hello everyone,
I generate VeriStand model from LabView project, however I have problem to create inports, which would be used in VeriStand. Every input in LabView project appears as a "parameter" in VeriStand.
The question is how to create a LabView project in such a way that input in LV will be an inport in VeriStand?
Pawel Krzesinski
(3,026 Views)
Accepted by topic author krzesniak1
Hi there!
Try setting the connector to the control as required in LabVIEW.
Best regards
Gustav
(2,981 Views)
