Verision 7.1
Greetings,
I am a newbie to LabVIEW using 7.1.  I wish to you x^2 but can not find it (taking x and squaring it) in the math tables.  Any suggestions?
Scamper
Message 1 of 8
(4,422 Views)
Hi Scamper,
are you searching for this (see attached picture in the red circle). Its from 8.5 but i guess its available in 7.1 too.
Mike
Message Edited by MikeS81 on 01-30-2008 02:45 AM
Message 2 of 8
(4,409 Views)
Simply wire the X to both the input terminals of the Multiply function, thats it. Smiley Happy
See the attached pic.
- Partha ( CLD until Oct 2027 🙂 )
Message 3 of 8
(4,408 Views)
Mike,
It is NOT available in 7.1. Smiley Sad
Message 4 of 8
(4,402 Views)
Hi parthabe
Ok, but i think your solution should work fine. Smiley Happy
Mike
Message Edited by MikeS81 on 01-30-2008 02:50 AM
Message 5 of 8
(4,400 Views)
Mike and everyone else<
WOW!  What positve and fast response.  Mike that was what I was looking for and have found out that it is not available in 7.1, but wiring the two inputs on the multiply function will do what I want.
Thanks!!!
Scamper
Message 6 of 8
(4,365 Views)
Hi Scamper,
While the x^2 (Square) VI is not available in LabVIEW 7.1, there is a VI called Power of X.vi (Found in the functions palette: Arith/Compare>>Numeric>>Logarithmic>>Power of X.vi). The inputs are X and Y and the output is X^Y, so just make Y=2 and you are set. I hope this helps!
Carla
Message 7 of 8
(4,363 Views)
Carla,
Thank you and everyone else on the chat site.  I could not believe the assitance I received when I posted my question.  Unbelieveable the help that I received!  Thank you and everyone else.
Scamper
Message 8 of 8
(4,344 Views)
