Version 1.1.1 of LabHSM Toolkit for Complex Event-Driven Development in LabVIEW – Small Corrections and Huge Changes in Licensing.
A new version of the unique toolkit is now available for download. As announced earlier, LabHSM makes it possible to easily create and then maintain complex event-driven applications in LabVIEW as a collection of HSM-driven active object VIs using a higher level of abstraction and agile software development methodologies. These active object VIs are created based on a universal Hierarchical State Machine ( HSM or statechart ) template. Therefore, all your code looks similar regardless of its functionality!
So, what’s new in version 1.1.1?
  • The code (made in LabVIEW 7.0 for Windows) now comes complete with block diagrams (password protected).
  • Simpler debugging code in the full template.
  • Extra menu items in the editor to open VIs as well as HSM files - nice to have when the LabHSM editor is the only VI open.
  • Copying of default actions is now implemented correctly.
  • No more run-time licenses! Just buy a developer's license once and distribute as many applications as you like!
  • The "Demo_" prefix is no longer required for VIs created in the trial version.
  • No more nag messages while running your HSMs!
As before, the LabHSM toolkit is available for UNLIMITED PERIOD trial. Please visit http://www.labhsm.com for details and download. The site also contains references which you may want to check to learn more about hierarchical state machines and active object computing.
Stanislav Rumega
NI Certified LabVIEW Architect
H View Labs
Message 1 of 1
(2,392 Views)
