Version 8.6 versus Versus 11
I compiled the program in 8.6 with out any problems. But I had too change 4 numbers. Now I keep getting this message. I am very new to version 11. Any suggestions.
Philip
(3,943 Views)
Did you search the help like the message suggests? If so, what is your question about it?
(3,936 Views)
This forum is getting pathetic. I thought we asked questions for answer not more questions. This case is closed. I do not want to use this stupid forum again. This case is closed.
(3,931 Views)
You can simply disable the SSE2 optimization as the message suggest it:
SSE2 is a compiling optmisation which only makes sense on some of the new processor architectures. You can get more informations on it if you want on wikipedia (for example) but in your case I would simply disable the option.
http://en.wikipedia.org/wiki/SSE2
Regards from Munich
______________
Florian Abry
Inside Sales Engineer, NI Germany
(3,930 Views)
Proper questions will return proper answers.
(3,920 Views)
Thank you for restoring my fath in the forums. I just wanted an answer. I had looked at the se section. But I kept coming up with compiler problems. We are all very busy today. The answer that I saw was not straight forward.
Thanks for inteligent people.
Philip
(3,880 Views)
