Versions of Labview and Teststand
Hello community,
We have several systems with Teststand and Labview installed, and I would like to know what the differences between the versions are and if there will be any compatibility issues when moving from one system to another.
Teststand
Version 2012 SP1 (5.0.1.66)
Version 2012 SP1 f1 (5.0.1.66)
Labview
2012 SP1 Version 12.0.1 (32-bit)
2012 SP1 Version 12.0.1f5 (32-bit)
2012 SP1 Version 12.0.1f9 (32-bit)
Thanks!
(2,831 Views)
the "f" and then number idicatates that it is a patch.  A system working with a patch will still run on a non-patched version (or older patched version).  Just make sure the patch did not fix a bug that you run into.
LabVIEW 2012 SP1 patch details: http://digital.ni.com/public.nsf/allkb/025C62799D95B78986257B130070EF62
TestStand 2012 SP1 f1 patch details: http://digital.ni.com/public.nsf/allkb/F46723204E4D177B86257B2E006F5082?OpenDocument&metc=upsrv_Test...
GCentral
(2,820 Views)
