Vertical Line on a Waveform Graph
I would like to generate vertical lines on my waveform graph based on a retuned index value from each of the plots.
I created the ones currently shown here using an array constant and replace array element, but this seems to be an ugly way of going about it.
Is there an easier way to display a vertical line at a location based on an index value that is returned from a plot?
(4,592 Views)
I would suggest looking at cursors
__________________
Engage! using LV2015
(4,557 Views)
Thanks...I will check that out! I appreciate the input 🙂
(4,541 Views)
