Very Strange Problem: tab command not send on run time engine
I am writing a vi to control a windows application, I need to BROWS to a folder on Folder Selection Menu. My vi send a command such as C:\MyDir\MySubDir to the application's folder enterring field, and followed by a "Tab" command.  Then the files in this folder should populate a list box in the application.  This worked on my Development station with LV8.2, but not working on the test station where LV Run Time Engine was installed.  Both PC have windows XP and service pack 2.   Does any one can guess what problem I may have?  Thanks in advance. -Bryan
(3,070 Views)
Hi BryanL,
Would it be possible to post the smallest portion of code that exhibits this behavior along with its executable? I would like to try and duplicate this behvior on my side. Thanks and have a nice day!
Steven
(3,054 Views)
Hi Steven,
Thanks for your reply. I found the problem to be my application was not properly copied into another folder. my mistatke.   Thanks.
(3,041 Views)
