Very basic waveform questions
Hi - for whatever reason, I have never been able to get my hands around graphs and their data. Currently I have a parallel loop running, which aquires the present reading from a piece of lab equipment . Obviously this output is not an array, but single points. What is the proper way of charting this onto a waveform chart? Should I be shifting the data out of the while loop, and then appending the new data to an array? Currently I use the 'build array' on the output, and send this to the chart.
By surface appearance this looks to work. However my timebase is off. Because the sample time is not always consistent, what is the best way to configure the dT/d0? Should I actively be measuring the time to aquire the signal, and piping this into the chart?
Thanks for entertaining my entry level questions!
Best Regards,
Jamie
v2009 devel. w/RT
Message 1 of 10
(4,630 Views)
Hello Jamie!
If you have timing information about your samples e.g. frequency, so you can connect 1/f to the dt input of your waveform. T0 is the absolute timestamp of your first sample. So you can connect the get the PC Time  getting your first sample and remember this absolute time and always connect to the T0 input of the waveform.
If your each package includes  a message counter or timestamp information, so use better the XY Plot.
If you have no timing informations and no timestamps, so you can use the waveform chart (not the graph), it will store/buffer samples for you, so you will not need to store them in a shift register and use build array VI.
Message 2 of 10
(4,624 Views)
Hi - thank you for your response and explaination. I have attached a VI, which works exactly as I need. 🙂
My next question is how do I combine the data to stack these two plots (vs overlay). In the past I have clustered the two 'arrays' of data, but I can not cluster the two waveforms. I tried to bundle the two waveforms, as well as build waveform (from output of two waveforms).
Getting there,
Jamie
v2009 devel. w/RT
Message 3 of 10
(4,611 Views)
You can use the Build Array VI to combine two Waveforms
 http://forums.ni.com/ni/attachments/ni/170/355668/1/Waveform.png
Message Edited by Eugen Graf on 09-15-2008 11:59 AM
Message 4 of 10
(4,609 Views)
Yes I tried exactly that, however the chart does not change between 'stacked' and 'overlay'. They both appear as overlay. My appologies, I meant to mention this in the last reply.
Message Edited by 8bitbanger on 09-15-2008 12:48 PM
v2009 devel. w/RT
Message 5 of 10
(4,597 Views)
I would suggest you have to duplicate the Y scale at first, and than you can stack your plots.
Eugen
Message Edited by Eugen Graf on 09-15-2008 01:27 PM
Message 6 of 10
(4,589 Views)
I'm not sure I follow - if by duplicate, you mean expand the 'create waveform' to include a second 'Y', it does not work. It simply takes the lower-most wired input as the value(s). Perhaps I'm not understanding what you mean(?)
Jamie
v2009 devel. w/RT
Message 7 of 10
(4,572 Views)
I don't know really right, but my suggestion doesn't work stable (not always). May be it's a LabVIEW bug.
But you understand me right, I meant the second Y-Axis.
Message 8 of 10
(4,568 Views)
I wasn't sure what version you are using but here is a quick mopup in 8.0. Note that I used a waveform chart. To get the plots to stack I had to expand the plot legend first then stack the plots.
 Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 9 of 10
(4,558 Views)
Yes that did the trick! Those sneaky folks at NI...
Thanks to you both for your help and better understanding! Perhaps I will update later with more questions, but for now I am good.
Best Regards,
Jamie
v2009 devel. w/RT
Message 10 of 10
(4,536 Views)
