Very slow writing with tdms of 2d DBL array
Comparing to saving of waveforms, the 2d DBL array is very and very slow.
For my defined data, 1D waveform took 7 ms, but 2D array (1D: data+1D channel) 4.1 s.
Unfortunately, I can't see the inside of TDMS write.vi.
How can I overcome this trouble, unbelievable performance?
labmaster.
To test other TDMS library, my attachment for LV 2009 requires the user library which can be downloaded from http://zone.ni.com/devzone/cda/tut/p/id/6471.
(2,914 Views)
And what is your reason for trying the G TDMS VIs? I would expect poorer performance with TDMS functions written with LabVIEW code as opposed to the native functions and would only use them on the OS's/LabVIEW versions without TDMS support. You have LabVIEW 2009 so are you trying for other OS support?
(2,905 Views)
I found my mistake.
Too many channels by transposing the array.
Forget my posting.
I intended to use it under Windows. So you are right.
Labmaster.
(2,899 Views)
