Very special issue with cRIO
"4.I orderd a Technical Sales Loaner. It should be here by tommorrow.
        The C-Moduls don't show up in MAX, only at a LabVIEW-Project"
OOOOOHHHHH... I thought you had meant the modules didn't show up in the project. C-Series modules aren't supposed to show up in MAX. There's the problem.
Edit: Sorry, I misunderstood... you were just pointing out to an above response that they were'nt supposed to show up. I got what you meant after looking at your screenshots. My apologies.
Cheers!
TJ G
Message 11 of 15
(669 Views)
Actually i meant that the my C-Modul didn't show up in the project. But yes, C-Series-Modules aren't supposed to show up in MAX.
Edit: Sorry, I misunderstood you, too, at the first read.
Message 12 of 15
(651 Views)
Finally I managed to connect to the C-Modul.
I opended the "Edge-Counter"-Example. When i added the Controller to the project LV automatically search for C-Moduls and found my NI9403.
The next Problem iss that "The compilation software is not installed"
I'm downloading Xilinx 14.4 right now.
Message 13 of 15
(634 Views)
One day later again the C-Modul can't be connected / detected.
The new C-Modul has arrived but can't be detected, too.
Message 14 of 15
(610 Views)
Hi Simon,
I don't know how hard you read my original post, but I think it's starting to look like you need to update firmware in the chassis itself as that appears to be the 1 constant you have here (you have changed all other SW drivers and HW modules from what I have seen). This is done from within MAX I believe. NI Technical support should be able to walk you through this process if someone doesn't post the process here!
Good Luck
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 15 of 15
(594 Views)
