Very useful tip to save time !
Working on some big project in LV 8.5 ?
Want to get rid of the few not-saved-yet modifications you've been working on for the last minutes in a few seconds ?
Just try to duplicate an event case that contains an indicator or a control and you're done... it merely crashes LabVIEW !
And Guess what it also "works" with a case structure, great !
AppName: labview.exe     AppVer: 8.5.0.4002     ModName: labview.exe
ModVer: 8.5.0.4002     Offset: 00ddeb2c
Side notes :
- in LV 8.0.1 and 8.20 the control/indicator is duplicated with an incremented name in the new case /event case
- in LV 7.1.1 the control/indicator is not duplicated in the new case /event case
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,229 Views)
Hi Titou,
thanks for your advice - but could you please provide more detailed or descriptive topics even when you're angry about losing work of a whole day ?!? (No auto-save enabled?)
Did you send a message to NI? Did you get an answer or CAR number?
I couldn't reproduce your error by setting up a simple small vi (without a project). No problem to duplicate event cases with control in them - new controls will be created with name counted up. So maybe this happens only for (big) projects?
Message Edited by GerdW on 01-21-2008 01:16 PM
(3,190 Views)
Hello GerdW,
You are right, I was a bit bitter when I posted this message, I apologize. Smiley Indifferent
While attempting to report this bug to NI, I realized that it was already in the know issues list, see here for link, CAR and workaround.
Message Edited by TiTou on 01-21-2008 01:29 PM
Epictetus
Antoine Chalons
(3,183 Views)
