Vi Failed to compile
Hello, I have a vi called "Execute Program Test.vi" which was working OK.
I tried to add an extra case to a case extructure but later I left everything as it was.
Tried to Re-compile (CTRl +Click Arrow) but nothing changed and after a few tries this actios closes Labview.
Also tried Heap Peek (Heap Pek FP and Heap PeekBD images )and on the list I looked for the red tag, I found it but it sems that it is only  remannet of a Select List or something similar. When I press F i get nothing. LV can't find the object as if the entry in Heap Peek was leftover.
Any Ideas?
(3,215 Views)
(3,214 Views)
I've had this problem before with other Vi, fortunately on those ocasions I just replaced the "damaged" vi with a copy from another of our systems.
Sadly for this new vi we don't have any other systems with it.
(3,212 Views)
