Vi Server - Open Frontal Panel remotely. Error 1043
Thanks so much.
And you know how to do with vi-server. Although I think that this is a very good way.
Regards.
Message 11 of 14
(1,097 Views)
No, cannot, never tried it with VI-server. Perhaps Ben can explain in more detail how he did it.
Can you tell us why you want to access the front-panel of a VI running on your sbrio on your host system?
Regards, Jens
Kudos are welcome...
Message 12 of 14
(1,092 Views)
Could you explain in detail this proccess please?
Thanks so much.
Message 13 of 14
(1,090 Views)
Thanks so much.
I provided an outline that builds on what you had already.
What part of what I posted do you think you need help doing?
I wrote about Action Engines in this nugget.
You are already open a ref on a remote node (the hard part by the way).
So figure out how to use a Call By reference node and design a AE that return the data you need and you are done.
Have fun! Once you get this figured out you will be more powerful.
Ben
Message 14 of 14
(1,079 Views)
