Vi. Show front panel when called. Close afterwards...
I have a vi with an event structure that's set to Show front panel when called. Close afterwards... The problem I'm having is is I use a switch called Continue to exit the loop and close the VI. When I enter the VI a second time  the Continue switch is still TRUE and it immediately closes the VI. I added a 2 second delay just to see if the window was opening.  I'm not sure how to make Continuous False when I leave the VI. Maybe make Continuous an input variable to the VI?
(2,235 Views)
I believe you're actually creating two value change events due to your "switching" mechanism. I would change that button to have a latching mechanism, and also put the terminal into the event where it will be read.
(2,209 Views)
Thanks Gregory. I'll try it out.
(2,160 Views)
