Vi for an accelerator transducer
Hi, I´m trying to simulate an acceleration transducer (HBM b12/200) in Labview. I wonder if anyone has created or knows where I can get this.Or al least any inductive acceleration transducer which is arranged in a half Wheatstone bridge.I´m using version 6.0.Thanks
(3,344 Views)
Hello;
I unfortunately couldn't find any VI doing that on NI databases.
Regards
Filipe A.
(3,344 Views)
Tengo el mismo caso: acelerómetro HBM B12/200 y trato de conectarlo al SCXI 1540 para adquirir datos en LabVIEW, pero no estoy muy seguro de la conexión, esta no funciona muy bien.
BoF
(3,147 Views)
Hola fboteroh
Te anexo un documento que te puede ayudar para realizar las conexiones de tu transductor tipo LVDT.
http://digital.ni.com/public.nsf/allkb/5FB0106294CE483886256A02006091A5?OpenDocument
Espero esto te sea de ayuda.
Saludos
Carlos Pazos
Senior Product Marketing Manager
(3,113 Views)
Thanks for your comments, I have to tell you that I have succesfully conected it completing the inductive bridge of the HBM B12, using resistors.
BoF
(3,095 Views)
