Vi-hierarchy
Hello.
I am modifying a labview program that someone wrote at my work.
And I have a probleme with vi hierarchy. A sub-vi appears in the
hierarchy named "creneau9c", but I can't find it in the diagram. When I
open the main program, Labview is loading it, but in fact, this vi is
not needed!
I don't know how to remove it.
Laurent TERRIER
LEGI - Ecoulements Diphasiques
1025 rue de la piscine - BP 53
38041 GRENOBLE cedex 9
Tel : 04 76 82 51 39
Fax : 04 76 82 52 71
(3,074 Views)
Laurent TERRIER wrote:
> Hello.
> not needed!
> Laurent TERRIER
You could try the "Find" function (after loading the top VI of course).
It is also possible that the VI is loaded using the server in which case
it will not appear as a subVI. The find should show it to you and you can
remove it.
Kevin Kent
(3,074 Views)
