Vi reference server
Can someone elaborate the use of this?
(3,739 Views)
Hi muks,
start with this link: http://digital.ni.com/public.nsf/allkb/F4010DD5C8D1B13D862565BC007384E9
Hope it helps.
Mike
(3,734 Views)
Yes. They're useful.
Oh, you mean you want more details?
Well, it's not a small subject and it's generally recommended to start by searching for tutorials and examples, either online or in the example finder (Help>>Find Examples). Here's one example. Here's another.
In one sentence, the VI server allows you to programmatically control VIs and controls.
___________________
Try to take over the world!
(3,733 Views)
I am confused with the explation for control reference and vi server reference.
(3,716 Views)
Control reference are part of the VI server hierarchy. The VI server has many classes of front panel objects (like controls and decorations), block diagram objects (like terminals, wires and structures) and other types. They each properties and methods which are used through property nodes and invoke nodes. The first link I gave has more details.
___________________
(3,708 Views)
Thanx tst.Will get back If i am stuck again(Most likely to happen).
(3,700 Views)
