Vi snippet changes local variable to reference+value property node
Ben wrote:
David,
I have not found any case where a snippet that used property nodes worked!
Take a look at this thread where I resorted to posting an image plus code since it was impossible to produce a snippet the would work right!
Ben
Having spent some time to think about how to implement a VI snippet functionality in pre 2009 I can see the difficulties about this. First, they certainly use the same code as used by Create SubVI from selection, to turn a selection into a temporary subVI to be turned into a VI snippet. This does the (turn locals into references with value properties) for obvious reasons. For the VI snippet case it shouldn't do that but rather include the connected terminal in the intermediate selection.
However expecting the front panel Z order to be exactly the same as in the original VI is likely to be impossible in many cases since the creation of such a VI snippet subVI will involve creation of additional controls for any wires that origin from a non-control source or go to a non-indicator sink not included in the selection. This will always involve adding extra elements to the selection list, and that will mess up the Z order in one way or the other.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 11 of 19
(2,223 Views)
rolfk wrote:
Ben wrote:
David,
Ben
Rolf Kalbermatter
How can I argue with one of my mentors?
The Snippets really have the potential of changing the look and effectiveness of the forums... if they worked right. In that thread I linked previously my snippet (with the improper property linakge) may have confused the original poster more than it helped.
In its current state it looks good but is border line useless.
Ben
Message 12 of 19
(2,210 Views)
Jeff Bohrer wrote:
Matt-
I'm thinking that this is actually a benefit.  Certainly the property node executes more effeciently.
Does no one else take exception to this?  If not, why not?
Tim Elsey
Certified LabVIEW Architect
Message 13 of 19
(2,197 Views)
elset191 wrote:
Jeff Bohrer wrote:
Matt-
Add me to the exception list along with Tim.
Locals are more efficient and do not require a switch to the UI thread.
Ben
Message 14 of 19
(2,190 Views)
elset191 wrote:
Jeff Bohrer wrote:
Matt-
Knight Ben did in reply #3.  "In general its not good because locals have better performance and does not force a UI thread switch."
Message 15 of 19
(2,189 Views)
I even double checked to see if anyone posted about it, so as to not look foolish.  So much for that...
Tim Elsey
Message 16 of 19
(2,184 Views)
No problems.  It was in there subtly.  I remember reading the thread before and I thought someone had corrected that comment.  After seeing your message, when I went looking for it again, it took a few minutes and flipping back and forth between the pages before I found the comment again.
Message 17 of 19
(2,174 Views)
Ben wrote:
David,
Ben
Hi Ben
Sorry for going missing on you, I'm on vacation at the moment and don't have access to LV and only intermittent computer access. I'll check the strange behavior when I get back or maybe one of my helpful colleagues will see this and have a look in the meantime?
Sorry for the delay and belated congrats on making Knight!
Best Regards
David
Message 18 of 19
(2,132 Views)
Hi All
I took a look at the problem in Ben's thread and I get the same thing. Also created some very basic examples of my own and they also had the same problem. So this very much looks like a bug, sorry. You can get around it pretty easy by recreating the property node or creating a new reference and replacing the generated one, but that's still a big hassle and it's not right. I created CAR 187861 for this problem. Will let you know how it goes.
Best Regards
David
Message 19 of 19
(1,994 Views)
