Vi to drive R/C servo
I plan on using a high precision R/C servo to control control surface deflections for an experiment that will be run in one of our wind tunnels. I would like to drive the servo with Labview and am curious if anyone has any experience doing it. I need to generate a pulse modulated signal to control the servo.
(3,049 Views)
You will probably get more responses to this question if you post it under the Motion category.
There is a motion control tutorial in Developer Zone you should check out titled "Determining the correct drive for your servo motor". http://zone.ni.com
There is also a KnowledgeBase entry titled "Specification Issues When Using the Servo NuDrive with a Specific Motor" that is worth checking out. You can search KnowledgeBase at http://www.ni.com/support
(3,049 Views)
