Vibrations Measurement
Hello everyone, I have a question, I am measuring vibrations with the 9230 card and the chassis 9174, and a frequency of 20 Hz appears and I can not understand where it could be, everything is working with batteries, so it is eliminated the influence of the network, I don't know if someone could help me explain why those 20Hz, when doing the FFT to the noise signal.
I thank you in advance, good day
(4,078 Views)
If you attached some images of the raw waveform and of your FFT, you might be able to get some some help.
If you are able to attach a data file that contains a section of the raw waveform so people can load it and inspect it.  Even attach your VI.
It is hard to debug a signal problem when all you have provided are a few sentences.  What sensor are you using to measure the vibration?  What physical thing is the sensor trying to measure?
(4,068 Views)
can anyone explain this?
CY (expired CLAD)
(3,990 Views)
The power network, presumably
(3,979 Views)
I have a ~24Hz  signal in my office-seismometer 😄
But I know the origine: we have a bad air condition unit with a bad fan on the roof 🙂
Type of sensor and cable length?
How and where mounted?
and a snipped of the DAQ wfrm read would be helpful.
Greetings from Germany
Henrik
LV since v3.1
(3,952 Views)
The sensor used is acelerometer ICP IMI model 603C01, first I'want measured the acceleration, but the aplications that I need is the velocity.
I probed the acceleration, to view the frecuency analisis.
In the process, I need to integrate the signal ... in the next step.
(3,911 Views)
yes, the power network
(3,907 Views)
