Video processing
I have the project which has to process video signal by doing the
particle analysis. In this case i already have the video input from
the measurement device, but i would like to know about which interface
modules, interface cards that needed to manipulate the video input
signal through the Labview.
Thank you in advance.
Skytalker ...
(3,019 Views)
Hello Skytalker,
The software and hardware that you need depends on your application and the type of camera that you are using. I would suggest taking a look at http://www.ni.com/vision. Here, you can find details on the vision products National Instruments offers. The Vision Development Module provides functions that can be used for particle analysis and has other image processing capabilities.
I hope this helps.
Vivek Nath
Machine Vision
(2,978 Views)
