Video transmission between two USRPs via antennas
I would like to send image between two USRPs via tri band antennas(wireless medium), USRPs connected to two different
computers
I was checking with wireless video link posted in the community.
But I was unable to select jpeg image file  on the front panel.Please help me
out regarding this issue.Please check with your LabVIEW 2015.
I am using two USRPs 2920 and 2932 in windows 7 ,32 bit PC, LabVIEW(2015
version)
Message 1 of 10
(4,971 Views)
Please include a link to the "video link posted in the community"
If it's this, then explain more about your issue. The JPEG image on the front panel is a picture ring. You can click on it and it will show three options just like in the instructions.
Cheers
Message 2 of 10
(4,965 Views)
Message 3 of 10
(4,959 Views)
Yes, I selected image option and then clicked to select image jpeg file but unable to select.
It is as if file tree is disabled
Message 4 of 10
(4,955 Views)
The link you've included returns an error on NI's site.
If it's the same example as what I linked, the picture control gets disabled once you hit "Start" because the value has already been set. You must set it up before hitting Start.
Cheers
Message 5 of 10
(4,946 Views)
It is the same link that you had posted."Wireless video link"
Message 6 of 10
(4,941 Views)
Okay, then please refer to my last reply relating to the Start button.
Cheers
Message 7 of 10
(4,934 Views)
Where is the Start button?Did you mean run button on the left top of vi?
I am trying to select the image file before running the vi but unable to do so.No JPEG image files in Pictures folder are  displayed while selecting image.What is the matter?How to select the file?
Message 8 of 10
(4,932 Views)
You need to run the VI (using the arror on the top left) before you can configure the program. It says this right in the instructions on the page I linked to. The picture ring is disabled and/or not populated until you start the VI. There is no point in changing values before running the VI.
This is the Start button that you press after you've configured the program.
I highly suggest you read and follow the instructions given.
Cheers
Message 9 of 10
(4,922 Views)
Is there an alternative way to send image using Packet based digital link? Text was successfully transmitted and received at other computer via antenna.
How can image packets be sent and retrieved in a similar fashion?
Is there a need to change packet parameters?
Memory becomes full at the subgenerate packets.vi before transmission of image.
Message 10 of 10
(4,911 Views)
