View Task/Channels In properties
Hello, I am working on a LabView program that was left by another engineer who's no longer here. There's an NI DAQ to acquire data, and I am interested in getting into the "Task/Channels In" properties to see how the DAQ is actually acquiring data. No matter where or how I click, it seems like I cannot view the parameters of the task. I can create a new task/channel in and set the voltage range, acquisition rate, sampling mode, etc., but I would really, really like to know the exact parameters the original engineer used to set this up. I have inserted a picture below - is there any way to get into the properties of the task called "validyne"?
(2,668 Views)
Accepted by topic author Akaf24
Those tasks are defined in Measurement and Automation Explorer, also known as MAX.  A separate program from NI.  Check your start menu.
(2,655 Views)
