Viewing google earth maps in labview
Jean-Marc
Thank you for all of your help. After exploring this VI it doesn't due quite what I wanted.
Is there anything out there that would allow me to continue running GE in a VI and plot GPS coordinates in real time (from a flight) and mark each of these points so that it will leave a trail?
Message 21 of 29
(3,321 Views)
It works pretty well but I still have a problem: The Vi works very fast at the beginning (I change navigate on the map very fastly) but after a few time (+- 40 sec) it becomes very slow.. Maybe this problem comes from the Stacked sequence structure, I don't know. Thanks for your help..
I am seeing the same thing after 5 minutes. I'm looking into this but any suggestions are appreciated.
Message 22 of 29
(3,189 Views)
Hello
I ´m doing a project, but I have the same problem after 4 minutes. Any suggestions to solve this problem??
Message 23 of 29
(2,982 Views)
I'm trying to use the embedded GE code in LV 2009 with the latest (5.2 i believe) version of GE. I keep getting timeout errors on the attempt to initialise, even though the code starts GE in a separate window. What compatibility issues might I be missing here?
Message 24 of 29
(2,788 Views)
intresting ...
i have downloaded this vi and i am not able to see ge on labview.
Is it because i dont hace that dll.
if yes then from where i will get.
please guid me to see what you have done
thanks
for wonderfull discussion.
CLAD
Labiew programmer
Message 25 of 29
(2,777 Views)
Played with this some more and discovered that it's 64-bit LabView that seems to be incompatible with GE. 32-bit works, though grabbing and moving the image in the embedded window doesn't work like it should. Is there a workaround to get GE to talk to 64-bit LV? I'm hoping to use that version as I need the ability to address more memory in other areas of my program.
Message 26 of 29
(2,752 Views)
Hi all.
I'm trying to develop a similar application: display a map on the LV front panel and locate several points using GPS data entry (latitude and longitude). I think I can do well with the VIs provided here, but after searching in the forums, there's something I can't clearly difference yet. Sorry if I'm asking a trivial question, but what's the difference between using Google Earth Plugin and Google Earth COM API?
Francisco
Message 27 of 29
(2,688 Views)
Hi all,
I want to use the Vi Test GE Embedded V2. It works very well. But now i want to show marks on the Google Earth Window.
Examble: I want to have a mark at the coords 49.3277505298106, 8.565757454496922. The mark should be placed on the GE Window.
Is that maybe possible?
Greets
Message 28 of 29
(1,915 Views)
hi all,
i am working on project to show google earth on labview but i am geting the error. the snap of error is attached with VI which i downloaded from forum. i am new user of to the Labview and found it good tool for pograming. i dont know why i am recieving the error any help would be loudly appreciated.
currently i am using LAbview 2012(64 bit)
GE installed is version 7.1.2.2041
windows 7 64 bit
thanks for the help
Message 29 of 29
(1,745 Views)
