Viewing the DICOM RT structure with DICOM images
LabVIEW can read DICOM images.
But How can I read the DICOM RT structure with DICOM images for radiotherapy application? The DICOM RT structure file is a *.dcm file format among the DICOM images.
(6,131 Views)
I'm not an expert, but at least your post get bumped.
As far as I can tell, the .dcm has the same structure as a .dicom file.  Reading tags in a dicom file is explained here: How-to-Read-and-Write-DICOM-tags (I wouldn't use that coding style, but it might inspire a solution.)
If the RT structure is a tag, and you can get it's data by reading a tag, it's a matter of converting the data. If that is the problem, please post the structure and example data.
(6,057 Views)
Thanks for your reply.
I'd like to display RT structure file(.dcm) on CT DICOM images with as below.
But, an attached .dcm file wasn't read when I use LabVIEW Read Image Express VI as well as built-in "3D Image reconstructor.vi" example using isosurface extraction.
(6,038 Views)
I can't run that because a) it's LV19 I need <LV18 and b) I don't have the biomedical toolkit.
The only think I can think of is to see what happens when you change (or copy) the .dcm file to a .dicom file. Maybe, just maybe, the Read Image tests for the extension, and generates an error.
EDIT: Never mind, the previous link uses .dcm files.
Have you tried that code? If the file doesn't open at all you might have bigger issues. Perhaps a newer version that isn't supported by the biomedical toolkit?
(6,012 Views)
Yes, indeed I try to read your link. General .dcm(CT images) files are good to read but RT structure file couldn't read.
Thanks anyway.
(5,972 Views)
Are you comfortable with Python? It's integration into LV is decent.
From https://github.com/pydicom/pydicom/issues/770:
There is an RTSTRUCT example file included in pydicom
 from pydicom import dcmread
 from pydicom.data import get_testdata_files
 filename = get_testdata_files("rtstruct")[0]
 ds = dcmread(filename, force=True)
(5,937 Views)
