Virtual Bench incorrect example code (for DC FGEN output)
I am using the example code from here: https://forums.ni.com/t5/Example-Code/VirtualBench-Generate-Standard-or-Arbitrary-Waveforms-With-the... for a virtualbench 8012. It can generate arbitary waveforms just fine, however when I ask it for a DC signal it runs without error but without actually applying a DC signal to the FGEN output.
Has anyone else experienced this or have a solution?
(3,881 Views)
Hi md12g12!
Here's a link that may help you, if that does not help let me know and I'll look for another solution for you!
https://forums.ni.com/t5/Example-Code/VirtualBench-Stimulus-Response-With-the-MSO-and-FGEN/ta-p/3996...
Best Regards, Monse
(3,831 Views)
Thanks, thats basically what I am doing, however that approach does not allow you to specify a DC signal. In the example I linked to, DC is one of the options (along with square, sine etc) however it appears not to function at all. Is there another way of generating a DC signal? I have played around with applying my desired DC offset to a square signal of ~0v amplitude but that seems like a very poor work around?
(3,814 Views)
Can you attached the code? I'm going to check some things and if I got it I'll tell you!
Monse
(3,809 Views)
Im afraid im not at a pc with labview installed for a while, but I am using the exact VI download from the linked page.
http://www.ni.com/cms/images/devzone/tut/FGEN_BD_20150310152135.PNG
Im using this in standard waveform. DC does nothing whilst the other waves work.
(3,805 Views)
Here is the vi I am trying to use. Settings are:
Waveform - DC
Amplitude - 5V
Duty Cycle - 50
Frequency - 1k (Hz)
DC Offset - 0V
(3,798 Views)
