Virtual COM. Detect event
Hi.
I have a Virtual COM port that allow me to emulate an RS-232 on a USB port. This means that when i insert an appropriate external USB peripheral, a new COM port in my system appears.
I wold like to capture the operation system event generated when the exeternal peripheral is removed (and the COM port disappears). Otherwise i must do a polling (or wait for a write error) to know if the exeternal peripheral is still present, but i wouldn't....
Please help me!
(2,766 Views)
you could use windows API to obtain this information, in particular you could pass trough the Microsoft SysInfo Control ActiveX.
This ActiveX can notify your program device add/remove events.
Take a look at these MSDN links for information
DeviceArrival Event
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/sysinf98/html/scevtDeviceArrival.asp
DeviceRemoveComplete Event
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/sysinf98/html/scevtDeviceRemoveComplete.asp
Looking for "ActiveX" in NI Example finder you'll find examples on registering activeX events.
With this been said, it could be a lot easier to create a subVI that calls "VISA Find Resource.vi" and look for added-deleted COM resources!
Ciao.
NicolaC
(2,733 Views)
