VirtualBench DMM trigger delay
Hello Community,
I am using Labview 2018 SP1(32-bit) & VirtualBench VB-8012.
I want the VirtualBench DMM to stabilize longer before taking a measurement. For example, the NI PXI-4072 has a vi "niDMM Configure Trigger". This states, "Trigger Delay (sec) specifies the time the DMM waits after it has received a trigger before taking a measurement.". I wasn't sure how to achieve this with the VirtualBench.
I noticed that there is a DAQmx Trigger and Triggering Node, but will this work with the VirtualBench in achieving that measurement delay?
Thank you!
Message 1 of 1
(1,197 Views)
