Vis that reside in different location but have a same name und different funktion
Can i use in LabView 5.01 Vis that reside in different location but have a same name und different funktion?
How? I don´t wand to rename the VIs.
(2,763 Views)
Sorry, you can't have homonymous VIs simultaneously in memory. You'll have to rename one of them.
LabVIEW, C'est LabVIEW
(2,763 Views)
Hoch kann i rename automatly in LabView 5.01 all the same Vis-name from a directory?
(2,763 Views)
You could always use the system exec and rename the files through a dos command. Otherwise, you will need to use the file I/O functions to open the files, write it to a different file name and delete the original file.
(2,763 Views)
